Re: cub farmall wont stay running
Posted by Harold Evans on February 20, 2012 at 18:34:06 from (98.220.4.76):
In Reply to: cub farmall wont stay running posted by deene on February 20, 2012 at 17:43:09:
Check for rust in the gas tank. Even the smallest pieces can cause these symptoms. Also, check to see if there is an inline paper filter and remove it. They get clogged very easily. No need for them in a gravity fed system with a sediment bowl. I have repaired two tractors with these same problems by removing the tank, cleaning it well, and applying a coat of plastic sealer to the inside of the tank. Not a single problem with either of them since then.
