Re: Super M Box Blade
Posted by DeltaRed on February 20, 2012 at 18:51:21 from (67.6.229.75):
In Reply to: Super M Box Blade posted by Moe Rocco on February 20, 2012 at 16:01:06:
I pulled a 9'x32' Eversman landplane with my SuperM for years.Pulled in 3rd gear with a 'full bucket'.The tractor also'wore'a set of duals.7' will be no problem-buy an 8 ft'r.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
