Re: torch check valve
Posted by Rod in MN on February 21, 2012 at 06:41:49 from (66.242.67.252):
In Reply to: torch check valve posted by tractordanp on February 19, 2012 at 15:59:51:
HI Guy's put the check valve at the torch end of the hose. Or you could end up like me. With 80% of my back burned 3 Spots were 3 deg. burnes. Had to wear a special vets for about 2 Yrars NOT FUN. The check valves were at the reg. Missed 30days of work. It took some time befor i would use the torch and when poped back when sone one eles was useing it i would about pump out of boots. THINK ABOUT IT EVERY TIME I USE A TORCH!!!! BE CAREFULL
Thank You
Rod in MN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
