Re: Farmall tractor gas line problem
Posted by JRSutton on February 21, 2012 at 11:50:48 from (75.130.109.233):
In Reply to: Farmall tractor gas line problem posted by mkirsch on February 20, 2012 at 14:26:39:
Almost surely some blockage in the carb.
Just remove it and clean it all out thoroughly.
I can't recommend a cheap ultrasonic cleaner highly enough. Drop the carb in, let it "cook" for a bit - and it'll be good as new.
