Re: Farmall 560 D injection pump injectors
Posted by Dillsburg 560D on February 21, 2012 at 12:10:54 from (12.109.64.99):
In Reply to: Farmall 560 D injection pump & injectors posted by Owen Aaland on February 21, 2012 at 04:03:48:
looks to be .310 plunger dia. If I'm reading pump number correctly. Going to be midget nozzles when done. Turning about 2350 rpm now. Should I go with 660 or 706 governor spring ? What will work for the most torque and power ?
