Re: I4 Motor
Posted by gene bender on February 21, 2012 at 17:55:05 from (67.55.226.168):
In Reply to: I4 Motor posted by henryv11 on February 21, 2012 at 17:40:46:
First i would gring it down smooth and get the area nice and clean then get some rubber cement that the body shops use when installing windshield. Apply a nice coat over the weld and you could use a trouble lite or a hair dryer to help cure. Give it good ample time to cure and it will probably outlast you. I have used it on a couple of Bs and that was many yrs ago and it still holds. Sure is worth a try. The stuff comes in a blue and black tube. Your leak doesent sould like a huge one where water can pour out fast cause you said weep. What do you have to lose just a little time.
