Posted by Janicholson on February 21, 2012 at 18:17:48 from (67.72.98.45):
In Reply to: Re: 656 resistor posted by Jamie656 on February 21, 2012 at 17:19:28:
Electronic ignition is a fine addition to the tractor. It doesn't change the distributor, or replace moving parts except the breaker points. as a result, if it did go belly up, the points can be put back in. I think they provide a better spark, and faster starts (when used with a hotter coil). Far less maintenance. The advance mechanism needs to be checked with a timing light to assure it is operational. The ignition still depends on that mechanical device. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
