Posted by 1sarge on February 21, 2012 at 19:46:44 from (24.233.240.41):
In Reply to: 350 TA Questions posted by 1sarge on February 21, 2012 at 19:11:05:
Thanks for the reply. I will decide if I want to just replace the clutch or do more. If it is now working in the low or TA then it is possible that just the clutch would make it work as it should?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
