Re: Re: Water Pump For C
Posted by Big Don on September 12, 2000 at 16:08:37 from (24.65.54.137):
In Reply to: Re: Water Pump For C posted by Brian Schmidt on September 11, 2000 at 20:39:49:
Brian:
I think you will find that the head gasket is the
other way around. The head gasket for water pump use has smaller holes than the head gasket for
thermo syphon or non water pump use.I always understood that this was to let the non pressure
flow move through the gasket easier with the bigger holes. Very often the use of the small hole gasket without a water pump will restrict flow and cause overheating problems.(the small hole is about half inch round and the big hole is an odd shape that matches the water passage in the block and head measuring about one inch across)
Hope this helps. Don
Post A Followup
: Re: Re: Re: Water Pump For C
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
