Re: 1586 update
Posted by rustcollector on February 22, 2012 at 07:40:24 from (67.142.161.23):
In Reply to: 1586 update posted by timis on February 22, 2012 at 06:49:58:
Tim,
I would wash it out good and reassemble. Might use a magnet and reach in areas where you can't reach by hand or see for more cleaning. Could the "key" piece be part of a pto spline? Put the torque tube back as it will fit. The adjustment, if needed, will be on the top of the arm that is bolted onto the tube inside. The arm should bolt to a flat spot on the tube and fit the same as it did before.
