Re: farmall cub alternator
Posted by K-Mo on February 22, 2012 at 08:55:08 from (67.55.164.5):
In Reply to: farmall cub alternator posted by Steve Bontrager on February 22, 2012 at 08:45:10:
A basic Delco 10SI will do the job. I would go with a 3-wire using the ignition switch to turn on the alternator. One-wire alternators require sufficient RPM to get them to kick-in. Your Cub runs at a much lower RPM than in an automotive application. After starting, you would probably have to rev it up to start the alternator.
