Took apart a horizontal distributor from its case. Only difference between the vertical and horizontal is that the gear end is different on the vertical-has to be a helical gear;makes sense. So i took the gear off the old one, put it on the newer one, and yes, it not only fits like a glove, timing is also the same. Now the big test--set it up and make it run!!
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
