Re: priming 460
Posted by El Toro on February 22, 2012 at 14:14:08 from (108.3.225.57):
In Reply to: priming 460 posted by Huskers86 on February 21, 2012 at 20:06:06:
We used a pressure vessel filled with engine oil that used air pressure to prelube an engine pumping oil through the oil gallery. You should have pipe plugs on that engine so you can get into the oil gallery. WE removed a pipe plug and installed a tube to pipe thread fitting. Then used a neophrene hose with a swivel nut that was threaded on the tube fitting. We had a pressure gauge installed and when when the gauge showed oil pressure we made a start. Hal
