Posted by D Slater on February 22, 2012 at 18:56:59 from (184.15.49.116):
In Reply to: Re: 350 TA Questions posted by Old-F20 on February 22, 2012 at 18:38:45:
You can check it out in a parts book or maybe online. Probably can see the # on at least one of those manifolds. One you have pictured is # 362437R2. LP calls for # 358308R1 in the picture I posted. Just pointing out the difference and hope it doesn't upset you.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
