Thank you for your response. Yes pulling the lever back has been attempted. It is a knowm bad T/A. I adjusted T/A to totally release possible pressure on that clutch and it appeared to help a bit. All T/A fittings were backed out as far as they could be. Seems over time as T/A was failing all adjustments were backed out as far as they could be to get all the life there was out of it. I am hopeing that now that all is loosened up over time will shift easier until I can split tractor and repair correctly, (new T/A installation). Thank you for replying. Greg
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
