Re: Re: Re: Re: beefing up a farmall h
Posted by John Alfred Smith,Jr. on September 12, 2000 at 19:00:43 from (208.24.235.167):
In Reply to: Re: Re: Re: beefing up a farmall h posted by You can't be too thin, too rich, or have too many Farmalls on September 12, 2000 at 16:23:57:
Rex, Time to get serious, On your H you can, since
you are allready in this engine I am guessing
pretty deep. Put a Super kit in it. Your engine
will have about half the difference in hp between
a H and a full SuperH. A kit will probably have
larger pistons and sleeves and all the other
usual parts valves ,springs, valverotators,ect.
When you repaint DON'T, I say DON'T put
Super H decals on you tractor. It is an H with
a kit,not a full super H . Good Luck
Post A Followup
: Re: Re: Re: Re: Re: beefing up a farmall h
