Re: '06 fenders on 560
Posted by Weldon K on February 23, 2012 at 09:04:18 from (98.16.39.132):
In Reply to: '06 fenders on 560 posted by EUG1206 on February 23, 2012 at 08:15:07:
I've never seen it done, but here is what I would do. 560 axle is square, right? Use a length of heavy flat bar stock 5/8 or 3/4 inch thick, 3 inches or so wide. Cut to length as needed. Drill 3/4 inch holes in bar to match with hole pattern in fender axle mount. Get grade five 3/4 inch bolts of sufficient length. Put fenders on top of axle, bar on underside. Use flat washers and lock washers as necessary. Tighten securely.
You may find that you need to weld small pieces of 1/2 bar stock to the underside of fender axle mount to keep the axle mount centered and square on the axle. If you do not want to weld to the fender axle mount, weld bars to the flat bar stock, it will serve the same purpose, you will just have to position the fender mount straight and square on the axle as you tighten the bolts.
