Re: tel-a-depth adjustment
Posted by pete 23 on February 23, 2012 at 10:26:15 from (74.32.238.142):
In Reply to: tel-a-depth adjustment posted by redgems on February 22, 2012 at 20:23:11:
You do not have the linkage oriented properly or gears not timed correctly inside valve. I bet when you raise hitch hydraulics are staying under pressure also. Move output lever on valve to a mid point of hitch movement, stop engine and that is approx where the linkage have to make connections. There are several minor adjustment that need to be done but this is a starting point and you may very well have to retime them gears.
