Re: farmall m low gears
Posted by Wardner on February 23, 2012 at 15:05:00 from (4.154.254.119):
In Reply to: farmall m low gears posted by pullinferJesus on February 23, 2012 at 10:41:01:
Put the M out in the fence row and get a SMTA, 400-450. Install 560 gears. If you wanna go nuts, put on 660 planetaries and make sure the TA works.
M low-low first requires new countershaft, new 2nd/3rd contershaaft combo gear, new mainshaft 1st/reverse gear, and new reverse idler combo gear. You can find that kit on the CaseIH parts catalog. You should check that source out to make sure that I am reasonably correct. I am clear that it takes four separate parts to make the changeover. I wouldn't bother. I'd get another, but later, tractor.
