Re: F20 bearing play in crankshaft???
Posted by Nebraska Cowman on February 23, 2012 at 16:27:54 from (66.252.115.26):
In Reply to: F20 bearing play in crankshaft??? posted by Tony Woodrum on February 23, 2012 at 16:17:47:
No, there should not be any perceptible play in the roller bearings. BUT, I don't think .010 will make a knock. At least not turning over by hand. And the tractor was still running the last time it was used. You could have a rough ball in the bearing making a noise. Keep looking, you will find it. I'm trying to think..... I had an engine a couple years ago that had a distinct clunk. as I turned it over by hand. I can't remember now what I found.
