Re: Reproduction under seat battery box, are they all the sa
Posted by CNKS on February 23, 2012 at 17:54:12 from (216.144.104.128):
In Reply to: Reproduction under seat battery box, are they all the same? posted by Dean Olson on February 23, 2012 at 16:32:48:
Nearly all battery boxes are make by OEM Tractor Parts, regardless of who you buy from. You can expect to make minor modifications such as alignment with the bolt holes, etc. Once done they are fine. There is another company that advertises in Red Power Magazine that I have read is higher quality. The company is Unique Design Workshop, De Graff, OH. 937-585-6475. Probably higher priced also.
