Re: farmal H electrical problem
Posted by wayne in mn on February 23, 2012 at 19:26:02 from (24.179.171.41):
In Reply to: farmal H electrical problem posted by farmalmarkmark on February 23, 2012 at 18:26:50:
The starter is locked into the flywheel teeth. Put transmission in 5th gear & rock the wheels so you see the fan turning. Or remove the starter & manually rotate the starter bendix drive out of mesh with the flywheel.
Reassemble & try again; leave the lights off.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
