If/ when you get the starter teeth loose from the flywheel ring gear, re-install it & try turning the engine over with the starter. If it still doesn't turn over, feel all cable & battery connections for heat. This includes the starter switch terminals, & the starter connection bolt. When you feel excess heat, that is where a high resistance is at. If you don't have a high resistance, suspect a bad battery.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
