Re: putting a 560 282 in a 660
Posted by mkirsch on February 24, 2012 at 06:11:14 from (64.80.110.75):
In Reply to: putting a 560 282 in a 660 posted by joe-illinois on February 23, 2012 at 17:59:17:
The extra RPMs in the 660 are offset by the planetary gears at the rear wheels.
It won't be a dog. It will pull every bit as good as a 560, if not better. At 1800RPM it will be about 25% slower than a stock 660, is all. Just run one gear faster.
You're not going to be full-time farming with this tractor, right? So who cares if it's a little slower than stock? It runs, it drives, it pulls implements, it looks good. That's what counts.
