Re: Regular wont start
Posted by oldiron29 on February 24, 2012 at 16:28:30 from (74.88.11.200):
In Reply to: Regular wont start posted by Mark Poss on February 24, 2012 at 15:54:33:
Mark, If you have fuel compression and spark the only thing left is timing. Pull #1 plug and see if the spark is at TDC or before or after. Adjust the timing accordingly. There are many holes in the mag coupler to change timing + or-
They flood easy. carb adjustment open 1 and half turns. Did you choke it at all? Just the other day I was going to give up and belt my 10-20
to start it. Just a couple crank more and she fire right up. when it running you can set the
carb and timing by ear and next time it will start easy. oldiron29
