Re: Gear shift pattern on a Regular
Posted by Super-H-Mike on February 25, 2012 at 10:29:38 from (76.164.144.78):
In Reply to: Re: Gear shift pattern on a Regular posted by James Williams on February 25, 2012 at 07:07:21:
third party image
This is true, mine will drag the rear tires even in 3rd when pull starting,but it will then catch and spin the motor over pretty good. The shift pattern is like a H-shape but 2nd and 3rd are switched from what you are usually used to seeing. So 3rd is forward toward the gas tank and 2nd is back towards you.
