Posted by Mark Peters on February 25, 2012 at 11:35:07 from (166.249.141.103):
In Reply to: 340 weight bracket posted by bigr on February 25, 2012 at 09:38:57:
Like Hal said, there is no front weight bracket per se. There IS a weight that bolts across the front of the tractor. It`s the same slab weight that`s used on the front of the Farmall 460 & 560. On the Farmall 340, the slab weight bolts into the front of the frame weights that get bolted onto each side of the front bolster - same place front cultivators mount. You have to have the side weights to use the slab weight. The same side weights also fit the Farmall 240 and 404. They can be found, but they`re not the cheapest. I have this set up on my 340, but no closeup pic. Go on tractor photo`s and search Farmall 340 and mine is on there, but hard to see.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
