Re: 1953 Super M
Posted by L. C. on February 25, 2012 at 12:29:17 from (204.12.175.65):
In Reply to: Re: 1953 Super M posted by farmall300u on February 25, 2012 at 11:25:51:
Thanks for the web page for date codes.
Although the codes do not go beyond 1947 which is "Q", the code on my engine block is 1*25*O. It is not a "Q" as was used in 1947 so that would make this block a 1945? Am I correct?
