Re: 560 valves or injector ?
Posted by Rich in IN on February 25, 2012 at 18:57:53 from (199.16.223.2):
In Reply to: 560 valves or injector ? posted by Andrew Psencik on February 25, 2012 at 18:44:36:
Probably exhaust valve, recheck by just cranking with fuel off, see if it sounds any louder. Can verify which cylinder by loostening each fuel line, when fuel is removed from weak cylinder smoke will be gone or much less if you have more than 1 weak cylinder.
