Re: WD-9 Injector Pump Removal
Posted by sflem849 on February 26, 2012 at 05:16:37 from (69.197.84.39):
In Reply to: WD-9 Injector Pump Removal posted by WD9ER on February 23, 2012 at 07:16:32:
The whole thing has to come apart to replace that seal. Is your pump overfull of oil/fuel? That will make it leak. There isn't supposed to be oil on that seal so it "shouldn't" leak. That is what the guy at Central Fuel in IA told me. Get you pocketbook ready if you want to fix that seal. It is $650ish to just put seals and gaskets in your pump (if there isn't a problem) and over $1000 to do an exchange. He said most of the time you are cheaper to do an exhange...
