Posted by Andrew Z on February 26, 2012 at 06:41:23 from (64.148.7.32):
In Reply to: No compression posted by IH Guy on February 26, 2012 at 06:38:10:
Check to make sure valves are not stuck. Pull the valve cover and rocker arm assembly easy job. Rap them with a hammer, should have a nice 'spring back to them if you get a valve that does not come back up or does not spring then you need to lube them up well and keep tapping.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
