Posted by El Toro on February 26, 2012 at 08:44:27 from (108.3.225.57):
In Reply to: No compression posted by IH Guy on February 26, 2012 at 06:38:10:
Pull the valve cover and see if the push rods are moving. Remove the cap from the distributor or mag and see if the rotor rotates during the engine cranking. Something may have happened to either your camshaft or timing gear if there's no movement. Hal.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
