F-20 WF Pics
Posted by Eric-IA on February 26, 2012 at 08:56:38 from (204.12.187.196):
third party image
third party image
third party image
Just finished up mounting a Schwartz wide front on a F-20.
It came off an old Oliver- had to have new spindles turned to accept the IH wheels. New bearings, bushings, ball studs on the tie rods- the whole 10 yards. I had to fab up a new cradle to mount the top of the wide front to the underside of the frame.
I had a parts tractor and cut the lower part of the pedestal off- don't worry you purists, I have the original one that can be bolted back on if I want to change it back.
I took it out for a spin and it turns easy. Hope to paint it this spring.
