Re: No compression
Posted by old on February 26, 2012 at 09:05:58 from (4.245.13.106):
In Reply to: No compression posted by IH Guy on February 26, 2012 at 06:38:10:
Well first off PB and motor oil is not very good for freeing up sticking rings. Fill the cylinders with ATF and let it sit a week. In the mean time pull the valve cover off and check that it doesn't have stuck valves. Also pouring some ATF down the muffler pipe will help free things up
