Re: replacing a C-113
Posted by gene bender on February 26, 2012 at 11:17:40 from (67.55.226.114):
In Reply to: Re: replacing a C-113 posted by 1960s on February 26, 2012 at 09:25:06:
Ive seen several of those engines used none had the place for the starter filled in. So if you want to put a hy system on you just need the pump and a short shaft on the steering shaft to clear the pump not hard to do. Have you checked the crank for the pilot bearing as you will need it for the tractor.
