Re: SMD Hydraulic system design
Posted by Janicholson on February 26, 2012 at 13:31:33 from (96.24.99.126):
In Reply to: SMD Hydraulic system design posted by Dan MD on February 26, 2012 at 12:07:29:
I would not. In my opinion, the open center system heat will not have the casting of the reservoir to dissipate is the intake is connected to the return. If the port you describe on the side is used for suction only the return could be plumbed into the bottom. Retapping that hole for 1" would be pretty easy.
The fluid would then enter and leave the res at different locations with little construction effort. Jim
