Re: H wheel width
Posted by CNKS on February 26, 2012 at 18:27:03 from (216.144.104.128):
In Reply to: Re: H wheel width posted by BibBob1939 on February 26, 2012 at 18:03:22:
Minimum tread width center to center is 64 inches with the wheels dished out as you have them. If it has 13.6 inch tires add 13.6 to 64 and you get 77.6 inches, with 12.4's, 76.4. You can probably squeeze it between the fenders. If it was my trailer, I wouldn't do that if it has 13.6's or larger. You can rent one. A bigger problem is you have the weight of the loader, with a 7000 lb GVW trailer you will likely have too much weight. If so you should rent one with enough GVW.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
