Re: stuck h
Posted by old on February 27, 2012 at 10:27:42 from (209.86.226.40):
In Reply to: stuck h posted by mmack on February 27, 2012 at 09:53:37:
I pop stuck engines loose all the time but if you find water in any of the cylinders forget it because you will have to take it all apart to get it free. If the cylinders are dry then fill them with ATF and let it sit a week or so. Then set a 12 volt battery on it an use short fast taps of the starter button with the plug out to see if it has freed up. I can take a week or a month or more. Always put the plugs back in to keep dirt etc out and always pull the to spin the engine
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
