Re: stuck h
Posted by gene bender on February 27, 2012 at 10:43:54 from (67.55.226.114):
In Reply to: stuck h posted by mmack on February 27, 2012 at 09:53:37:
Remove the sparkplugs and use a good flashlite and you will be able to see the cycl walls and if they are rusty you are going to completely tear the engine down. Theres a reason its stuck and if the walls are rusty you will need new sleeves and pistons and maybe more. It realy doesent take too much to pull the head as probably some valves are stuck also. Myself i would pull the head then go from there its the best way to see how the cycl walls are. Saves alot of messing around trying to get it free the money you spend on snake stuff will buy a new head gasket. Pulling the plugs and just looking at them will also tell you a bunch.BTDT.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
