Posted by Dean Olson on February 27, 2012 at 11:58:13 from (75.53.109.201):
In Reply to: stuck h posted by mmack on February 27, 2012 at 09:53:37:
If the visual inspection of the cylinder walls justifies it I use 50% acetone and 50% ATF. Fill the cyclinders full. I put it in gear and rock it every couple days. If that doesn't work then I use a little more force and use the hand crank or put a socket on the belt pully nut on the front of the motor. It that doesn't work then I start taking the motor apart. I was taught that you never pull a stuck motor as that can create more damage.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
