Re: stuck h
Posted by rustyfarmall on February 27, 2012 at 12:18:46 from (216.248.71.224):
In Reply to: stuck h posted by Mike1972chev on February 27, 2012 at 09:53:37:
Of course there is always the option of pulling the motor, removing the crank, and then use a BIG press to remove the pistons and sleeves as a unit. You can then break the sleeve and peel it away from the piston so you can remove the piston pin and salvage the connecting rods. New sleeves, pistons and a few other things and you've got a brand new motor.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
