Re: stuck h
Posted by sflem849 on February 27, 2012 at 12:27:40 from (69.197.84.39):
In Reply to: stuck h posted by Dalrymple on February 27, 2012 at 09:53:37:
rustyfarmall said: (quoted from post at 13:18:46 02/27/12)
Of course there is always the option of pulling the motor, removing the crank, and then use a BIG press to remove the pistons and sleeves as a unit. You can then break the sleeve and peel it away from the piston so you can remove the piston pin and salvage the connecting rods. New sleeves, pistons and a few other things and you've got a brand new motor.
My grandpa will pull the crank (on flathead Fords, but the concept is the same) and then take blocks of oak and metal bars and use the bars pushing on the oak pushing on the pistons as a press. He will use penetrating oil of some sort in the process. He doesn't talk much and this is about all I know.
Edit - This is a long term thing. Like do this and then wait a few days or weeks and they will pop loose from the oil and constat pressure. Same concept as parking a tractor on a slight incline in fifth gear.
BTW, if I wasn't going to work on this project right now there is nothing to lose by pouring some diesel down the exhaust. Might as well start the process of breaking things free. ATF/Acetone or brake fluid are probably just as good, but not quite as cheap as diesel. There are probably a million other things that work, too.
This post was edited by sflem849 at 12:30:01 02/27/12.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
