Posted by ken house on February 27, 2012 at 13:58:42 from (173.242.240.50):
In Reply to: stuck h posted by mmack on February 27, 2012 at 09:53:37:
my C engine stuck, sitting outside. manifold had a hole and let water into motor.
soaked engine with lots of things. tried turning with crank starter, screwdriver in ring gear, etc etc. pulled oil pan. put jack under rod bearing and jacked front of tractor completely off ground. then put screwdriver into ring gear to assist jack. it came unstuck and seems to be o k.
not recommending anything. it is your tractor. i figured mine was no good as it was.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
