Yes it did. Mine is that way, but it is prone to foaming and continuous flow would probably do it in at some point. I have seen where several people have used the return at the bottom technique and it seems okay as well. I now have a separate 3 spool valve with a filter right after that on the way back to the tank.
For crawlers IH actually just recirculated the oil directly back to the pump. They use a check valve arrangement to keep the lines filled from the reservoir. (Crawlers need to work on steep inclines) Gets just a little warm but these pumps aren't fast enough to worry about heat. If the crawler doesn't heat up with a 82 GPM pump, a 12 GPM SMD is good to go.
If you do run a T down below, have the return line go straight through towards the pump.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
