Re: stuck h
Posted by John A. on February 27, 2012 at 15:06:22 from (76.1.122.180):
In Reply to: stuck h posted by mmack on February 27, 2012 at 09:53:37:
mmack,Burn it out! This method will get the job done in one afternoon. Follow my direction here.
1..Remove all, hood gas-tank, nose cowel, and radiator, Head and all wiring harness. Pan, oilpump, and rod caps. Have the tractor where you can roll it outside, CLEAR AREA OF GAS CANs, GREASE RAGS AND ALL FLAMMABLE THINGS!
tractor is now outside.
2..fill the cylinder with the most volume with Diesel add a splash of Gas, Set it on fire. Go get a cup of coffee and enjoy till the fire has burnt itself out. Take a block and a 4 lb sledge and drive the piston out from the bottom.
3.. repeat #2 on the next 3 pistons with the most volume. As you work your way down to the cylinders with the least volume the #of burning will go up to generate enough heat to pop the rust around the rings.
This method will allow you to at least inspect the piston and sleeve to see if they are salvageable.
***The first two usually go pretty quick the last 2 take a little longer.
***If motor is on a engine stand you can rotate the engine over for easier driving of the block.
Hope this helps!
Later,
John A.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
