Posted by Lmack on February 27, 2012 at 19:41:09 from (24.131.58.167):
In Reply to: Seized or not posted by Crocket104 on February 27, 2012 at 17:59:27:
If it had a cover over the exhaust it may not be that bad. If it is outside in a high rainfall area there is water in the transmission/rear end. Before you crank the engine remove the drain plug under the rear axel and drain the water off. As soon as you have oil coming out put it back in. You do not want to mix the oil and water as it will make a very big mess. (The reason I know is because I did not drain the water off and I had a mess.) You probably will want to replace the rear end oil at some point in the future.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
