F 20 Flywheel Removal
Posted by Bruce Nelson on February 28, 2012 at 10:37:37 from (208.157.191.167):
I need to remove the flywheel. The engine is out and the big nut has been removed. Now I see something that looks like a dowel pin, between the crankshaft and the flywheel, that is drilled and tapped to 3/8" NC. Do I need to get this dowel out to remove the flywheel, and how is the pin removed? Thanks.
