Re: 113 Farmall Sleeves
Posted by Machine249 on February 28, 2012 at 11:07:51 from (76.100.246.141):
In Reply to: 113 Farmall Sleeves posted by S/C Bob on February 28, 2012 at 08:34:10:
Your standard bore should be 3" if someone put in an oversized kit then it would be 3 1/8". However, the I&T manual states "Reject pistons and sleeves if a spring scale pull of 11-14 lbs. will withdraw a 1/2" wide, 0.0035" thick feeler gauge." It also says new pistons and sleeves should be checked with a 1/2" X 0.0025" feeler gauge and a spring scale pull of 4-6lbs. That is straight from the book. Don't forget to check taper and out-of-round as well. Hope this helps and good luck.
