Re: Water pump question on CaseIH 495
Posted by Bill_SC on February 28, 2012 at 12:22:45 from (207.144.207.219):
In Reply to: Re: Water pump question on CaseIH 495 posted by Bruce from Can. on February 28, 2012 at 11:53:46:
Well when it first happened I was plowing (under heavy load) and I noticed the hood wet around the cap and water apparently coming from under the cap. Whenever I removed the cap (later after it cooled) I put water in until it was at the bottom of the neck. Started tractor. Ever so slowly, the water level got higher and higher until it was trickling over the lip. Never had it gushing out or bubbles, just slowly rising. Now it had to have had a bit more than a trickle of force when it came out when in use, but then it would have been hotter and under pressure too.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
