Re: stuck h
Posted by rustyfarmall on February 28, 2012 at 13:08:16 from (216.248.71.224):
In Reply to: stuck h posted by glennster on February 27, 2012 at 09:53:37:
That system does work. I've seen it in action, but I don't know just how badly the engine was stuck. I've even tried it myself, but was NOT successful because the valves were stuck open also and all I did was pump hydraulic oil into the exhaust manifold.
To do it right, you need to use a tractor with a 2-way hydraulic system, and have the hoses connected to 2 different engine cylinders.
The adapter is relatively easy to make. Just knock the center out of a couple of spark plugs and weld in a hose coupler.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
